Forums >> Revit Building >> Technical Support >> SPIRAL RAMP ALONG CONE SHAPE BUILDING
Thu, Feb 11, 2010 at 2:39:00 PM | SPIRAL RAMP ALONG CONE SHAPE BUILDING
brlbdg
Hello,
I AM TRYING TO CREATE A SPIRAL RAMP THAT FOLLOWS ALONG THE INSIDE WALL OF A CONE SHAPED BUILDING.  THE WALL IS A PERFECT CIRCLE AND SLOPES TOWARDS THE INSIDE.
Thu, Feb 11, 2010 at 5:56:44 PM | SPIRAL RAMP ALONG CONE SHAPE BUILDING
TKennedy
4 Stars: 8 Votes
I just tried it and was able to do it with swept blends. In plan I had a 180° arc for the path. I created the profiles in elevation. At the beginning of the ramp I sketched the ramp in section, then at the other end I took the same section but moved it up and in. Then I copied and rotated the swept blend, moved it up and edited the profile sketches.
Curve L-shape ramp
Sun, Oct 21, 2012 at 11:23:15 PM
solid concrete cone
Thu, May 7, 2009 at 9:27:53 AM
Spiral wall along ramp
Fri, Jul 11, 2008 at 2:42:59 PM
How to make a cone shaped building..?
Thu, Mar 25, 2010 at 2:29:56 AM
Helical Ramp
Wed, Mar 10, 2004 at 8:51:07 AM
Page generation time: 1.4851
