14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Complex Brickwork Aesthetics
17 Posts No Rating |
Hi, i am wondering to incorporate a twisting effect brick pattern onto flat and curved walls for my design. Inspired by the two images below - i am wondering how it could be incorporated into a design similar to Image 2. I have considered facing by this may be tricky and could result in a high performance requirement. Could it be done with a curtain wall system? Thank you for any help. (Revit 09 & 10)
WOW. That would be cool. I would try the curtain wall. Make a "panel" with the pattern and see what happens.
----------------------------------- BallewDesigns.com |
I thought of a way to do it a couple of days ago. Although yet to try it as maybe very processor heavy. Thinking to model a two height brick part with mortar joints etc then copy and twist it above. Once a story is complete. Then to repeat the desired width required and combine into one mass. Then to finally split it vertically in half so that one side is complete flat and can be just pasted onto a flat wall. Hope that made sense. Yet hoping it won't be too processor heavy. If it is then may have to have a shot at 3ds max doing it. But have very little experience with it.
Look at this: http://autodesk-revit.blogspot.com/search/label/modelling Maybe this can help you
Shaded brickwork in elevation |
Mon, Jun 25, 2012 at 8:03:58 AM
Show brickwork only |
Tue, Aug 31, 2010 at 6:10:29 AM
Cavity closer - only closes on brickwork |
Fri, Nov 9, 2007 at 4:37:59 AM
Complex Revit Drawings |
Wed, Feb 2, 2011 at 5:55:23 PM
Families - Locking complex geometry |
Thu, Dec 4, 2014 at 10:48:22 AM
