Forums >> Revit Building >> Technical Support >> Revit 2010 Win7x64 rendering???
Wed, Feb 10, 2010 at 10:37:50 AM | Revit 2010 Win7x64 rendering???
iuserevit
I've installed Revit 2010 Arch on a Dell Precision T5500 with 6GB of ram. I am having trouble rendering models. When trying to render, the render progress window pops up for 3 seconds and then disappears and my model shows up with a black box. Is anyone experiencing this problem?
Wed, Feb 10, 2010 at 12:40:39 PM | Revit 2010 Win7x64 rendering???
4 Stars: 205 Votes
Wierd... One question: did you check the "Sun" parameters?
Wed, Feb 10, 2010 at 1:17:33 PM | Revit 2010 Win7x64 rendering???
iuserevit
i changed the sun lighting to what you had configured and the render progress window disappears and my model becomes a black box again.
Wed, Feb 10, 2010 at 1:24:22 PM | Revit 2010 Win7x64 rendering???
4 Stars: 205 Votes
I didn't told you to change that, i told you to check if you had change the "hour", if you have a night hour it will render black....
Wed, Feb 10, 2010 at 1:27:59 PM | Revit 2010 Win7x64 rendering???
iuserevit
i've set it to 1pm in the afternoon and it was still box black.
Wed, Feb 10, 2010 at 1:57:38 PM | Revit 2010 Win7x64 rendering???
4 Stars: 205 Votes
Hummm, try to delete that camera view and create a new one, render and check if the problem persists... did you install the Web updates for Revit 2010?
Wed, Feb 10, 2010 at 6:50:11 PM | Revit 2010 Win7x64 rendering???
hisdirt
5 Stars: 5 Votes
Hi there iserevit,
How close is your camera to a wall? I had it before when the camera is actually inside a wall, even when the view seems fine in the camera model view. Try nudging the camera away from the wall and re-rendering.
Hope this helps!
Thu, Feb 11, 2010 at 2:39:35 AM | Revit 2010 Win7x64 rendering???
Kardiff
5 Stars: 3 Votes
I would open up a project where you have previously done a successful render
and try re rendering them
 if they dont work then you know its a bigger problem then just in your projectif they do work, then you just need to tweak something silly that spoiling it(like your camera is just indoors or something)
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Lost rendering capabilites? (Revit 2010)
Mon, Nov 9, 2009 at 9:20:14 PM
Rendering with a jpeg in the background... Revit 2010, how?
Fri, May 14, 2010 at 3:39:09 AM
revit rendering
Thu, Oct 14, 2010 at 8:33:24 AM
Question on Revit Rendering in Quad Core Computer
Wed, Jun 10, 2009 at 11:38:38 AM
Rendering - Revit 2010
Mon, Jun 8, 2009 at 6:02:10 PM
Page generation time: 4.2626
