Forums >> Revit Building >> Technical Support >> insert a cad file in section or elevation..
Tue, Feb 9, 2010 at 2:25:39 AM | insert a cad file in section or elevation..
durgeshbrijwasi
i am trying to link a cad file ... but by default it is going in the plan view...how do i insert it in a elevation or an section..???
Tue, Feb 9, 2010 at 3:55:39 AM | insert a cad file in section or elevation..
4 Stars: 205 Votes
Go to a elevation or section view, then insert the cad file.
Tue, Feb 9, 2010 at 4:43:23 AM | insert a cad file in section or elevation..
durgeshbrijwasi
its still not happening.....
Tue, Feb 9, 2010 at 6:39:06 AM | insert a cad file in section or elevation..
gprakash
While importing CAD drawings, did you check the option 'Current view only' ?
Tue, Feb 9, 2010 at 6:50:54 AM | insert a cad file in section or elevation..
durgeshbrijwasi
YES I DID....
Tue, Feb 9, 2010 at 7:17:52 AM | insert a cad file in section or elevation..
What you have been told is the correct process.  You must be doing something different.
Tue, Feb 9, 2010 at 7:22:57 AM | insert a cad file in section or elevation..
durgeshbrijwasi
ok then.. i ll keep trying...thanks
Wed, Aug 11, 2010 at 4:49:31 PM | insert a cad file in section or elevation..
allisonkapler
Im having the same problem, did you figure it out? I also for some reason cant see my building in two of the elevation views and when I create a new elevation all the curtain wall is missing, any suggestions?
Wed, Aug 11, 2010 at 5:18:23 PM | insert a cad file in section or elevation..
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
If you go to visibility and graphics-->imported categories, is the box "show imported categories in the view" unchecked??
Wed, Aug 11, 2010 at 6:58:23 PM | insert a cad file in section or elevation..
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
Drag and drop it to an elevation... never phails
Tue, Apr 16, 2013 at 2:33:59 PM | insert a cad file in section or elevation..
#11
FWelliot
I had a similar issue.  When I imported the DWG into the elevatoin it oriented to view and was nt visible.  I went to the level it was placed at and saw that it was placed behind my elevatoin.  I simply moved it in plan to be infront of my elevation tag and it showed up. Need to put it on a workset to be sure that it won;t be in any unwanted views.  Hope this helps.
Tue, Apr 16, 2013 at 2:41:20 PM | insert a cad file in section or elevation..
#12
You have to be careful here.  What you have described is a "model" dwg insertion and you will even see this in 3D.  That is why it was workplane dependent.  If you uncheck the "visible in all views" box during import, then it becomes a 2D import.
Tue, Apr 16, 2013 at 2:48:03 PM | insert a cad file in section or elevation..
#13
FWelliot
Right you are.  I tried again with the current view only box checked and it did pop in properly without need for adjustment.  Thanks
RA 2008:: Detail components out of place on 2d element insert from file
Wed, Dec 22, 2010 at 3:30:17 PM
Scaling section and elevation markers
Thu, Jul 26, 2012 at 7:13:35 AM
Linked File Section Question
Mon, May 5, 2014 at 10:24:09 AM
Importing a METRIC CAD survey file generates topo lines at wrong elevation
Thu, Aug 12, 2010 at 9:40:21 AM
2021 proper/typical method to insert civil CAD to generate revit topo then place
Thu, Jun 10, 2021 at 10:36:47 AM
Page generation time: 1.0380
