9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Showing walls from the bottom of slab
118 Posts No Rating |
I want to know what's the best way to do this?I create a level below 0'-0" (sub slab).From the reflected ceiling view of the level, I can see the bottom of the slab and slab edge below the floor slab.From this view, I want to show the walls above the slab. How can I make the slab edges visible, the walls visible and the floor slab invisible in this view?
Did you try over-ridng graphics in view by element for the slab and making it transparent?
Yes, that's right. Right now, I just hide the slab in this particular view. How do you make the slab transparent?
Un-hide it...then right click on it - select over-ride graphics in view...check the transparent box....
Cool. It works. Now, the next question. After I make the element transaparent by overriding it, how do I restore it back since the element becomes invisible? I realize that you can make the elements halftone of transparent, is there a way I can make them in certain color? Like RED?
Gee ........Why don't you just experiment with the options you see when you use the over-ride function....
No problem. Thanks again for your help. I appreciate it.
Thickened slab appearance |
Fri, Jun 8, 2012 at 10:43:23 AM
Slab not showing in 09 |
Fri, Jun 20, 2008 at 8:21:54 AM
REVIT PROMPT: Would you like walls to attatch to this floor's bottom? |
Sun, Apr 24, 2011 at 9:25:55 AM
Foundation walls / vs slab edge sweeps |
Wed, Nov 8, 2006 at 6:10:43 PM
How can I add clear Height (floor to bottom of slab above) in a Room Tag? |
Sun, Aug 21, 2016 at 3:08:14 AM
