14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Cut Profile and columns
When I use the cut profile I get this error only when I am trying to cut the column. A wall in the same secton or callout cuts fine. What am I missing?
----------------------------------- Thomas W. Hillis, LEED AP |
I couldn't get the column to Cut Profile seperately but if I place a wall into it, or place a wall and align, it will Cut. You can place the wall, remove it, then go to section and it will cut. It must adopt some new characteristics once this is done, but I think it should do it one its own without the workaround.
Check your HELP menu...
I understand Cut Profile, just try it with a column seperately and see if you don't get the same result. It seems columns are a problem, not walls, floors, etc.
Showing columns from the floor above |
Mon, Jun 9, 2008 at 1:49:48 PM
big problem with edit cut profile???? |
Sun, Sep 11, 2005 at 9:38:48 AM
Cut Pattern - Timber Columns in plan views to black ? |
Tue, Mar 18, 2014 at 7:41:46 PM
Structural Columns not cutting walls |
Mon, Jan 4, 2016 at 4:13:25 PM
Cut Profile Line Weights (Revit Glitch?) |
Tue, Aug 22, 2017 at 4:23:29 PM
