Forums >> Revit Systems >> Technical Support >> Move Loads Around in Panel Schedule
Fri, Feb 5, 2010 at 12:12:07 PM | Move Loads Around in Panel Schedule
IanRevit
I am circuiting some devices, Revit picks whatever circuit it wants.
Can I somehow go in and move things where I want?
eg: Lighting on the left side of the panel, power on the right, etc?
I think it is done in AutoCAD MEP, but Revit MEP?
Using Revit MEP 2010
Thanks,
Ian
Thu, Feb 11, 2010 at 2:59:21 PM | Move Loads Around in Panel Schedule
anna2004
4.5 Stars: 3 Votes
Select the panel and under electrical select circuits the grab the one you want to move. You can move them left right up or down but be carful it is tricky.
Tue, Feb 23, 2010 at 3:06:53 PM | Move Loads Around in Panel Schedule
jcrocco
3 Stars: 1 Votes
Yeah, you cant move one without moving all those below it.
They really need to fix this for the next release.  It is so bad, we dont even use it.
If you want to move #18 to #10, then #10 becomes #12, #12, becomes #14, 14 to 16, and 16 to 18, all to move one circuit.
Must not have had an engineer on staff when designing how the panels worked I guess.
adding existing loads to a panel schedule?
Thu, Mar 28, 2013 at 3:56:42 PM
adding existnig loads to electrical panel
Tue, Feb 23, 2010 at 9:32:02 AM
no loads in the panel schedule
Tue, Aug 4, 2009 at 3:58:12 PM
Electrical Panel Schedule
Tue, Sep 14, 2021 at 9:18:20 AM
Wall Panel Location
Thu, Dec 14, 2006 at 11:49:47 AM
Page generation time: 0.9426
