Forums >> Community >> The Studio >> Parametric Arrays
Thu, Feb 4, 2010 at 9:30:30 PM | Parametric Arrays
MrRevitUser
Just wondering is it possible to make a parametric array that has parametric components.
I want it to be fully parametric so that I can change the size of the elements in the array through parameters and have the array resize, add or subtract elements as needed.
thanks.
Fri, Feb 5, 2010 at 3:19:22 AM | Parametric Arrays
4 Stars: 205 Votes
If you search in the forum you will find several threads with this same issue and if you look at the bottom of this page you will see some of them....
Parametric Arrays - Detail Item Help!
Fri, Jan 29, 2021 at 9:03:59 AM
Parametric Arrays?
Wed, Apr 1, 2009 at 3:38:48 PM
Revit 2009: Familly with parametric arrays - Voids wont cut
Tue, Aug 19, 2008 at 3:46:02 PM
Multiple Paramteric Arrays on a beam
Thu, May 17, 2012 at 3:01:18 AM
Parametric Array
Wed, Feb 8, 2006 at 11:14:52 AM
Page generation time: 2.8655
