Forums >> Revit Building >> Technical Support >> editing families when creating new
Fri, Sep 9, 2005 at 5:27:20 AM | editing families when creating new
Will9000
4 Stars: 5 Votes
Hi, Can anyone advise as to how to create a family that is editable, all families i have created seem to be blocks? Thanks in advance
Fri, Sep 9, 2005 at 11:44:13 AM | RE: editing families when creating new
TomDorner
4.5 Stars: 25 Votes
By editable I assume you mean parametric. Families that are parmetric require reference planes/lines, contraints/alignments and parameters to control them. It is a pretty in-depth topic. It is best to go through some tutorials on the subject, read some books or take a class. Some re-sellers now offer Revit classes just on families, check with yours. The Autodesk courseware on Revit advanced edition covers family creation and can be purchased from Autodesk. Autodesk University in November offers a "families from the beginning" class, but it is already full. If I run across any more ideas I will post them. HTH Tom
Fri, Sep 9, 2005 at 11:47:45 AM | RE: editing families when creating new
Will9000
4 Stars: 5 Votes
Ok thanks for that. better start reading Will
Fri, Sep 9, 2005 at 3:17:20 PM | RE: editing families when creating new
TomDorner
4.5 Stars: 25 Votes
I finally found the link to the old Revit Distance Learning seminars. They used to hold these live, but now there are only the old 6.0 ones recorded. Most of what they talk about is still valid in 8.1. There is one on families you might find value in. http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=5055212&linkID=3770350 The other option is: http://www.dgcad.com/Revit8.htm They have some free lessons and other are $9.99, but none on families yet. HTH Tom
Editing Families
Fri, Oct 8, 2010 at 12:02:03 AM
Editing and creating new wall types
Fri, Dec 14, 2007 at 10:17:54 AM
error in creating new families
Wed, Feb 22, 2006 at 3:28:05 AM
Help editing All in one Revit Content families
Mon, Dec 21, 2015 at 1:27:25 PM
Creating Specialty Equipment Families
Tue, Nov 18, 2008 at 5:43:42 PM
Page generation time: 0.4612
