Forums >> Revit Building >> Technical Support >> Room Tag w/ Dimensions and other calculations
Thu, Feb 4, 2010 at 12:34:30 AM | Room Tag w/ Dimensions and other calculations
iamian33
iamian33 Avatar
Greetings.
Does Revit Architecture 2010 provide the ability to create a room tag that includes:
  1. the dimensions of the space (ie. 8'-9" x 12'-3"Winking?
  2. the occupant load based upon the area of the room?
  3. useable / rentable (BOMA) square footage calculations?
I was advised by my reseller that 2010 had overcome this issue and will support calculations using the area or volume of a room ... TRUE?  If so, can someone point me in the correct direction?  :o)
 Ian
Ian Shafer
Principal Consultant
True North S&F Consultants
Thu, Feb 4, 2010 at 8:06:27 AM | Room Tag w/ Dimensions and other calculations
You can schedule this information but it can not be placed in tags parametrically...
Thu, Apr 29, 2010 at 1:15:40 PM | Room Tag w/ Dimensions and other calculations
iamian33
iamian33 Avatar
bummer ... but thanks for your input.  Maybe Autodesk will get there.  They should 'borrow' this from Autocad :o)
Ian Shafer
Room Dimensions in Tag Family
Sun, Aug 31, 2008 at 9:23:36 PM
automatic room dimensions tag
Fri, Nov 8, 2013 at 2:16:28 PM
Room Tag & Room Dimensions
Mon, Mar 13, 2006 at 3:11:05 PM
ROOM TAG HEADACHE!!!! PLEASE HELP
Thu, Dec 4, 2008 at 12:15:23 PM
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
Page generation time: 2.1814
