Forums >> Revit Building >> Technical Support >> Creating a Brick Jackarch Window Header
Wed, Feb 3, 2010 at 10:29:10 PM | Creating a Brick Jackarch Window Header
ldonkle
Our company is converting from another BIM software (Vertex BD) to Revit, and we're having trouble re-creating our Brick Jackarch family in Revit.
(see attached pics for what we're trying to achieve)
In the OLD software, we created this trim point-by-point with COORDINATES.  CryingI've attached the code we used to create the coordinates if it helps.)  Can anyone think of a way to do this in Revit?  Let me know if I need to be more specific.  Thanks.
Thu, Feb 4, 2010 at 4:09:01 PM | Creating a Brick Jackarch Window Header
jterrell
3 Stars: 5 Votes
Use model lines on the face of the extrusion.
Thu, Feb 4, 2010 at 4:17:30 PM | Creating a Brick Jackarch Window Header
ldonkle
Forgot to say it needs to be parametric.  Varying window widths.
Arch Top Window Header
Mon, Mar 5, 2012 at 3:43:08 PM
Problems with visibility of Header and door openings
Fri, Jul 26, 2013 at 11:05:23 AM
brick sill below window on brick wall
Thu, Mar 13, 2008 at 6:10:23 PM
Need help with window?
Tue, Nov 24, 2009 at 1:38:33 PM
CAST STONE HEADER OVER A WINDOW
Mon, Nov 23, 2009 at 7:53:32 PM
Page generation time: 0.3752
