Forums >> Revit Building >> Technical Support >> Door with portholes and symbolic lines
Thu, Sep 8, 2005 at 7:35:09 PM | Door with portholes and symbolic lines
Sparrow
I am trying to create a door with 2 circular glass portholes and symbolic lines to show the correct opening direction. I can't seem to get the lines to draw where I need them. Can anybody give me some tips?
Thu, Sep 8, 2005 at 10:29:31 PM | RE: Door with portholes and symbolic lines
eldados
eldados Avatar
4.5 Stars: 8 Votes
are you having trouble with the glass position or the symbolic lines? if lines you are talking about, in elevation use the pick tool and lock into place using the little lock symbol (what else?) Smile
Fri, Sep 9, 2005 at 12:18:31 AM | RE: Door with portholes and symbolic lines
Sparrow
I am trouble creating an opening. The opening keeps saying "not cutting anything" and I can't get it onto the right plane. I'll just use the Void tool instead. I also can't work out how to draw the symbolic lines in the correct plane.
Fri, Sep 9, 2005 at 11:15:37 PM | RE: Door with portholes and symbolic lines
eldados
eldados Avatar
4.5 Stars: 8 Votes
are you trying to cut the door in the project??? or the family? in the family use void and make sure after you finish your sketch to tell the void what to cut and also make sure that it is actualy going through the door... not infront of my Revit right now, trying to get the old memory going Smile
Windows above the Cutplane and Symbolic Lines (Revit2010)
Wed, Jul 14, 2010 at 7:35:42 AM
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
symbolic lines
Thu, Jul 13, 2006 at 8:15:41 PM
SYMBOLIC LINES
Thu, Aug 16, 2012 at 7:01:09 AM
Symbolic lines
Tue, Dec 26, 2006 at 2:24:22 AM
Page generation time: 0.3592
