Forums >> Revit Building >> Technical Support >> Coordinating faced based models with Revit MEP
Tue, Feb 2, 2010 at 3:00:35 PM | Coordinating faced based models with Revit MEP
kore24
So we're trying to working with our MEP engineers on a project.  One problem we're coming across is coordinating our ceilings.  The issue is they say the need our lighting fixtures to be "faced based" so they can make their connections in Revit MEP.  The problem with that is now when we move our ceiling grid in any direction the lights no longer move with the grid, since they're faced based instead of being hosted to the ceiling.  Has anyone resolved this issue or have any suggestion on better ways to work with our engineers?
Tue, Feb 2, 2010 at 3:53:48 PM | Coordinating faced based models with Revit MEP
I believe they are wrong.
What they need is their own faced based lights that have their connections.  Your lights will not do them any good.
They will then place their lights whre yours are and turn your lights off.  Their lights need to be face based because you own the ceiling.
Tue, Feb 2, 2010 at 4:04:02 PM | Coordinating faced based models with Revit MEP
kore24
The reason the MEP guys want faced based is so they can directly connect to our fixtures instead of going through and changing them all out.  Is there a better way to collaborate with them?
Tue, Feb 2, 2010 at 4:07:04 PM | Coordinating faced based models with Revit MEP
Your lights have no connections that I know of!
Best Practices - Coordinating Column Grids Across Arch. and Structural Models
Wed, Nov 11, 2009 at 9:32:25 AM
MEP host based fmilies needed!
Thu, Apr 4, 2013 at 7:35:45 AM
Linking Revit MEP, Structural Models into Revit Architecture
Mon, Apr 23, 2012 at 4:00:03 PM
REVIT MEP - Separate models for MEP disciplines
Tue, Jun 25, 2013 at 1:45:42 PM
Faced-based families Revit Systems
Wed, Oct 3, 2007 at 6:23:30 PM
Page generation time: 2.3769
