Forums >> Revit Structure >> Technical Support >> Is it possible to rotate footing / elevation / etc. tags?
Tue, Feb 2, 2010 at 1:21:56 PM | Is it possible to rotate footing / elevation / etc. tags?
jmorabito
Maybe this is a dumb question (I hope it is)...but I have no clue.
Is it possible to rotate foundation tags, elevation tags, and so on (the families I mean) without creating a new family for every single angle known to man?  I'm working on a job that is very asymmetrical and am getting very frustrated with creating a new family for every different angle that a footing is at...
I tried checking the option in the family that says "rotate with component" but that doesn't seem to do anything...neither does the "keep readable" check mark.
 Thanks
Tue, Feb 2, 2010 at 1:28:40 PM | Is it possible to rotate footing / elevation / etc. tags?
jmorabito
Also Spot Elevations...can those be rotated?
Footing Tag
Tue, Aug 25, 2009 at 12:06:55 PM
Footing Elevation Tags
Wed, Jan 31, 2007 at 12:53:22 PM
Rotate Tags
Thu, Nov 10, 2011 at 12:33:08 PM
Elevation View Tags
Tue, Nov 24, 2009 at 8:46:28 PM
Attaching a footing to a column with a base plate nested into the footing family
Thu, Jul 11, 2019 at 12:23:42 PM
Page generation time: 1.8388
