Forums >> Revit Structure >> Technical Support >> Section cut lines
Tue, Feb 2, 2010 at 9:31:20 AM | Section cut lines
mike321
I cut a section in 2 parts dividing the crop region. Where those 2 sections where cut I would line to show a cut line. When I draw the cut line over the crop region boundry line of course the lines disappear when the corp region is turned off. The attached detail shows the cut line circled that I would like to produce. The cut line has been pull down the wall of the detail. I need it to appear where the wall was cut. I'm new to revit. I'm using revit structure 2010.
Tue, Feb 2, 2010 at 9:44:41 AM | Section cut lines
TKennedy
4 Stars: 8 Votes
What cut line did you use? The cut detail component cannot be outside the crop. The way to get around this is to add a masking region in the cut family on one side of the line that will cover the model. Look at the one in the Revit library.
Is it possible to not have the bold section cut lines
Thu, Apr 3, 2008 at 12:58:16 PM
Placed Sections on Sheet, Plan Cut Lines Disappeared, But the Sections Remain
Sun, Dec 2, 2012 at 7:34:52 PM
section cut lines
Mon, Jun 2, 2008 at 1:37:48 PM
Section cut with clipping
Wed, Mar 25, 2009 at 10:12:21 AM
Extra Roof Lines in Section
Thu, Jan 28, 2016 at 12:45:54 PM
Page generation time: 1.0484
