24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Autocad imports PDF's. Is there anyway Revit does that?
Autocad lets you select which page from a batch PDF file, when imported you can pick on lines like you can when you import dwg's.
Sorry. No pdf import /link yet in Revit.
13 Posts No Rating |
You will need to convert your PDF to TIF format, should be pretty simple in Adobe. Once you have that you can import the TIF into Revit directly onto a sheet or in a drafting view.
Welcome to Revitcity. How long have you been using Revit?
Hogmodo, are you talking to me? I have been on RevitCity for about 3 years, I've just been an observer, not so much a participator. Thanks for the welcome... if you were talking to me....
I suggest that if you can trace PDF lines in CAD, that you do that, then import.... Better than using a raster image.
I actually imported a 24x36 original size PDF as a tif. I was able to click on the top right corner to start a line going straight down 192' (24" @ 1/8 scale = 192'). Then I drew a long line to the left, selected the image, clicked and held the bottom right corner to drag it to the line and "wallah" it was scaled to 1/8" in my 1/8 scale plan. You still can't select the lines to "trace" over them but it is a little bit of a help.
Incompatibility between ''Bluebeam'' pdf fillar and Autocad dwg. |
Wed, Aug 19, 2020 at 7:59:03 AM
revit to autocad-dwg to pdf |
Mon, Mar 20, 2017 at 3:11:13 AM
11
Problem import Autocad file that contains ''proxy entities''. |
Wed, Mar 17, 2021 at 7:38:19 AM
Can't figure out PDF printing. Help! |
Tue, Sep 12, 2006 at 4:39:07 PM
Printing PDF's |
Tue, Oct 26, 2010 at 11:21:57 AM
