17 Users Online (15 Members):
Forums >> Revit Structure >> Technical Support >> Question about elevating footings
15 Posts No Rating |
I am using Revit Structure 2010. I don't know if this is possible or not...so here we go. I am elevating the footings on my current job. Typically the footing snaps to the bottom of the column which is all fine and dandy, but my columns were all put in with an arbitrary height initially b/c we didn't have the footings sized. I see under the instance properties for a footing there is a line that says "dimensions" and below it is a greyed out "elevation at bottom" line. Is there a way to make that editable? Being able to type in the elevation would be a huge time saver as opposed to typing in the offset from the reference level. Thanks.
No, that parameter is calculated by Revit and cannot be manually edited. It really shouldn't be that hard to give all the footings an offset though. What I did when I was in structure was have a separate level for the main footing heights (e.g., top of pad footings, top of wall footings). Then I just had to give a couple oddball footings an offset from that level.
Ah thats unfortunate. Yeah it won't be a problem to do it with offsets, I just happened to notice that greyed out elevation earlier and thought that could make life a little easier but its all good. Thanks for the quick response.
Elevating curved walls |
Tue, Jan 17, 2012 at 8:30:11 AM
Footings for Slab Foundation |
Tue, Oct 30, 2007 at 7:05:08 AM
Auto Footings |
Tue, Apr 4, 2006 at 10:10:15 PM
Footings, getting double hidden lines and intersections suck! |
Fri, Aug 31, 2012 at 10:13:08 AM
isolated footings not showing up |
Wed, Jul 18, 2012 at 1:17:11 PM
