23 Users Online (21 Members):
Forums >> General Discussion >> Revit Project Management >> Sketchup topo to Revit
Some time ago I watched a video online on how to export an existing site from Sketchup to Revit. I cannot find the video anymore but maybe some of you know how to do it and explain me how to... thanks
Go to the Site plan view then "Import CAD", change the extension to SKP, select the Sketchup file, check the units, colors... then OPEN, now in Toposurface "Create from import>Select import instances" pick in the skp file, i hope you have that with elevations...
Thanks thyphoon, importing the file worked the only thing is that when I tried to create the topo from the "Create from import>Select import instances, that did not work. any ideas/solutions? what do you mean by " i hope you have that with elevations..."?
The model must have "Elevations Z" - (points with x,y and Z), i never used sketchup "Site" model to create my toposurface in Revit, i always use DWG files with contours lines with right elevation (Z)...
1 Posts No Rating |
https://www.youtube.com/watch?v=R1X8Ux_4wJI
Best way tutorial of this ive found to date.
Revit to SketchUp |
Thu, May 28, 2009 at 9:44:11 AM
lines on topo surface |
Wed, Aug 3, 2011 at 8:37:21 AM
Sketchup to Revit |
Wed, Aug 26, 2015 at 10:41:27 AM
Sketchup model into Revit |
Tue, Jan 8, 2013 at 12:06:20 PM
SketchUp to Revit |
Sun, Mar 22, 2009 at 6:53:33 PM
