Forums >> Revit Building >> Technical Support >> parametric fill pattern
Mon, Feb 1, 2010 at 11:17:43 AM | parametric fill pattern
hunterfloyd
i'm attempting to create a family for an object for some phasing drawings.  what i want to do is have the ability to change the color of the fill pattern inside the object to demonstrate how it will be phased.  how can i add the parametric ability to change the fill color of this family?  revit '10.  thanks for the time.
Mon, Feb 1, 2010 at 11:33:00 AM | parametric fill pattern
TKennedy
4 Stars: 8 Votes
I looked at it a little bit, and I'm not seeing a way to change the color of a fill pattern with a parameter. What I know would work however, is to create multiple fill patterns, and turn them on and off with parameters. It's not as clean as what you are looking for, but it would work.
Mon, Feb 1, 2010 at 11:41:19 AM | parametric fill pattern
hunterfloyd
is it possible to create a new and delete the other fill pattern in different "types" within a family? so type 1 is red. type 2 is green. and type 3 is yellow?
HuntFlo
Mon, Feb 1, 2010 at 12:15:21 PM | parametric fill pattern
TKennedy
4 Stars: 8 Votes
Absolutely, although the fill patterns won't actually be deleted, they just won't be visible. One fill pattern will have a visibility parameter assigned to it called something like "Vis 1", the second will be "Vis 2", etc.. Make them type parameters, then in the type properties check or uncheck the appropriate parameters. I attached a small family so you can see what I'm talking about.
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:36 AM
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:24 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Fill Pattern
Mon, Jun 5, 2006 at 8:13:21 PM
Fill Pattern not show up when print
Wed, Apr 25, 2012 at 4:08:55 AM
Page generation time: 0.3434
