Forums >> Revit Structure >> Technical Support >> I need Global Project changes to CAD Import lineweight, linetype, etc.
Mon, Feb 1, 2010 at 9:04:15 AM | I need Global Project changes to CAD Import lineweight, linetype, etc.
BobSchaefer
My firm is switching from ACAD to Revit. We are using standard details/sections from ACAD to compose standard detail sheet in Revit using drafting views. Of course, line weights and types do not match up with Revit because we have used a custom color based plot file. Is there a way to use something like a script file to change layer linetype color to adjust pen shots to correct the line weights Globally rather than individually for each CAD Import?
Mon, Feb 1, 2010 at 2:46:04 PM | I need Global Project changes to CAD Import lineweight, linetype, etc.
CAD imports are really going to bog you down so if you are really converting to REVIT, I suggest you turn these into Revit details ASAP.
Read this in your HELP. Setting Line Weights for Imported DWG or DXF Files
Edited on: Mon, Feb 1, 2010 at 2:54:38 PM
Mon, May 3, 2010 at 11:27:12 PM | I need Global Project changes to CAD Import lineweight, linetype, etc.
iamian33
iamian33 Avatar
with all due respect, WW ...
there are hundreds of firms with well-established detail libraries created in Autocad.  The blanket suggestion that a firm abandon their detail library and begin again is not a cost-effective approach.  Autodesk will need to provide a mechanism to assist in a quality import of these details.  It's about workflow ... and cash flow!
I am having the same issue Bob.  Did you find a resolution?
Ian Shafer
Principal Consultant
True North S&F Consultants
Linked Cad - Global Lineweight
Wed, Sep 2, 2015 at 4:54:03 PM
(2015) import (link) CAD to Revit screened lines (lineweights)
Wed, Sep 30, 2015 at 2:20:54 PM
Getting CAD Linetypes into REVIT
Thu, Jul 24, 2008 at 7:11:10 PM
Structural Footing Lineweight Issue
Mon, Jun 18, 2018 at 12:05:57 PM
Handy Linetype
Sun, May 7, 2006 at 8:14:27 AM
Page generation time: 4.5170
