22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Equal dimension stumper
RAC 2010 the front porch part of the floor moves with the front wall- but i need it to remain center when i move one of the side walls..
forgot the image..
Your question is clear only to you. Not sure what walls you re talking about but no matter. Here are several questions: - When you created your floor, did you associate your floor to the walls or sketch it seperately?
- What are your dimensions really too? The obvious walls ... or the floor. When dimensioning, look at what Revit says you are dimensioning too and if you have to, tab to pick the right object.
"when you created the floor did you associate it to the wall?" that's why i said the floor moves with the walls.. if that's what you mean by "associate".. "What are your dimensions really too?" that's what i'm asking- what do i need to dimension to for the front porch part of the floor to remain center when i move one of the side walls.. in other words- all of the floor (including the porch) move with the moving of any four walls- BUT the porch does not stay centered when i move a side wall.. how can i make it stay centered when i move a side wall?
EQUAL CONSTRAINT DIMENSION |
Mon, Jan 10, 2005 at 1:06:29 PM
No Equal Toggle for Arc Dimensions?! |
Fri, Nov 6, 2015 at 2:57:13 PM
Centering Elements WITHOUT using the "Equal" dimension |
Mon, Nov 24, 2008 at 2:38:42 PM
equal dimension curtain wall NOT SHOWING EQ |
Thu, Dec 8, 2016 at 9:01:53 PM
Dimension String Doesn't Equal Overall Dimension |
Wed, May 27, 2009 at 2:33:49 PM
