Forums >> Revit Building >> Technical Support >> Site plan under building
Sun, Jan 31, 2010 at 4:08:26 AM | Site plan under building
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
RAC 2010
how do i put a site plan with building pad under a
building model that is already near finished?
Sun, Jan 31, 2010 at 7:16:40 AM | Site plan under building
4 Stars: 205 Votes
This question is very vague... do you have 2 different files? one for the site and other for the model? If yes "Link" the site in the model file....
Sun, Jan 31, 2010 at 3:35:22 PM | Site plan under building
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
i will change the word "put" to the word "build"..
how do i build a site plan with building pad under a
Mon, Feb 1, 2010 at 8:42:07 AM | Site plan under building
If you have a CAD file with either points or topography lines, you can import that and create your model site.  Read about that in your help. If you just want a 2D site plan, link the dwg or draw the site plan as 2D linework.
If you already have a modeled site, just add your pad.  You can read about pads in your help.
Site Plan & Moving Building Model
Fri, Mar 9, 2007 at 10:22:55 AM
Same Building on Site Plan with different elevations?
Fri, Dec 14, 2012 at 3:59:33 PM
Linking Building to site
Mon, Jan 5, 2009 at 1:41:36 PM
Cant see site features in First Floor Plan
Thu, Jan 31, 2008 at 7:10:59 AM
Site plans and Linking with Master files
Fri, Jul 7, 2006 at 6:55:40 PM
Page generation time: 1.6685
