12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Orient section cut to object
17 Posts No Rating |
I'm trying to re-orient a section cut (actually I'm using Detail cut) to a foundation wall, since I've rotated the wall in plan. Is there any way to do this withoug erasing the Detail and starting over? I've already dimensioned and annotated the detail and don't want to lose that work. I can rotate the detail symbol in plan, but can't snap to any part of it so my orientation is only approximate. Thanks
MacBook Pro 2.66 GHz Intel Core i7 running Windows 7 Pro 64-bit on Parallels 6 |
Any way without starting over? Not sure. If you've already detailed the section, you can copy and paste from view to view.
Thanks, it's more the tedium of view setup tasks that don't come with applying a view template, such as stretching out and arranging the levels, that I'm trying to avoid.
Well. Yes, you can do it. It's a bit tedious...but it can be done. Probably easier to just create a new section...maybe not. Follow the link. Notice the trouble I have snapping to the correct endpoint. I eventually get it, but you'll get the point. http://www.screencast.com/users/MOwens/folders/Jing/media/15c56adb-1100-4fbd-8d0d-87af9f535b65
I have had succes at just drawing a line perpindicular to my wall and if it doesn't intersect my section, I move the section to where it intersects my line. Then I chhose the section and the rotate tool, move my rotation point to the intersection, then grab the end of the section and rotate to the line. Delete the line.
2D drawing instead of hatch pattern for cut sections views? |
Fri, Dec 25, 2015 at 8:41:33 PM
Animate section cut? |
Sat, May 29, 2010 at 5:15:48 AM
Sectional Perspective NOT cutting in the N,S,E and W direction |
Mon, Oct 3, 2011 at 2:29:47 PM
Object Style - Mechanical Equipment section workaround? |
Wed, Jul 16, 2008 at 4:18:14 PM
Having issues rendering a 2D section |
Sun, Dec 18, 2016 at 11:04:31 PM
