Forums >> Revit Building >> Technical Support >> Triangular roof slabs: Controlling corner heights
Thu, Sep 8, 2005 at 1:44:59 PM | Triangular roof slabs: Controlling corner heights
filter
I am looking for an easy way to make a roof like the one in the attached pdf sketch. The triangular floor slabs have different corner heights. I need to be able to control/change the elevations of these corner points easily in the design process. What I dream of is to be able to sketch the footprint of a triangular slab, and then set the elevation (from base level) of each corner point. I've been experimenting with the slope arrow but can't seem to find a intuitive way of making this work as smoothly as I want. Any suggestions? Post edited on 2005-09-08 13:46:14
F/LTER
Thu, Sep 8, 2005 at 6:23:26 PM | RE: Triangular roof slabs: Controlling corner heights
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Best method would be to create a mass extrusion with voids to cut the top to the appropriate level. Then use roof by face.
Complex Roof (spaceframe)
Mon, Jun 30, 2008 at 11:18:14 PM
one roof two wall heights
Mon, Apr 6, 2009 at 11:34:59 PM
Roof Join at a Corner
Mon, Aug 27, 2007 at 10:33:22 AM
This Roof is driving me Crazy!!!
Fri, Jul 27, 2018 at 12:40:30 PM
Rounded roof corner
Thu, Dec 15, 2011 at 8:06:29 AM
Page generation time: 0.2783
