Forums >> Revit Building >> Technical Support >> Sill plate?
Wed, Jan 27, 2010 at 9:22:08 PM | Sill plate?
Arch145763
Im trying to attach a sill plate and rim board to a foundation wall. If there is an easier way to do this I would appreciate any additional information but here is my issue.
 I loaded dimentional lumber from the structural framing family, I place the sill plate on the wall but it draws it to the inside corner of the wall so the sill plate does not extend to the edge of the foundation wall. I try to align the wall and sill plate but it does not allow me to do it and no error comes up. How do i get the sill plate to go all the way around the top of the foundation wall?
Thu, Jan 28, 2010 at 7:05:51 AM | Sill plate?
Most people never model elements that are within a wall.  We just add them as detail components in sections and details.
Thu, Jan 28, 2010 at 7:08:22 AM | Sill plate?
HDDWG2003
HDDWG2003 Avatar
3.5 Stars: 11 Votes
You can try making the sill plate with a sweep.
Thu, Jan 28, 2010 at 9:26:44 AM | Sill plate?
TKennedy
4 Stars: 8 Votes
When I was doing wood framing I created a profile family that I could place inside the wall for sill and double top plates. I seem to remember putting a dimensional lumber section detail component in the profile, but I can't remember exactly why. I think It had to do with making it look right in a section view.
Thu, Jan 28, 2010 at 5:10:16 PM | Sill plate?
jarosa
jarosa Avatar
4 Stars: 5 Votes
Use the align tool. Select the o/s of the wall. Hover over the end of the sill plate. Click tab until you get the shape handle. Select the shape handle.
OR -
Add a sweep to the wall in the type properties. That way when you add, move walls there won't be any extra work.
Creating a "Compound" Profile
Thu, Feb 11, 2016 at 10:22:24 AM
Keynote by sheet
Mon, Jul 18, 2016 at 6:46:33 PM
Wall Sweep for 2 x 6 Sill and 4" Cap Block
Thu, Feb 11, 2016 at 9:15:08 AM
plate not saving
Fri, May 2, 2025 at 1:22:19 PM
Wall Reveal - not behaving
Fri, Oct 24, 2008 at 12:56:48 PM
Page generation time: 1.7478
