Forums >> Community >> Newbies >> Color of walls and window/door trim
Wed, Jan 27, 2010 at 4:12:51 PM | Color of walls and window/door trim
rcobbjr
3.5 Stars: 3 Votes
It has been two years since I have touch Revit. Now it is at 2010 Sad. I am creating a model of a residential structure. The trim/moulding around the doors/windows is a brown, wooden color. I need to change the color to reflect that the moulding is white. How do I do that?
Also I want to "paint" the walls. How do I change the color on the wall to reflect the actual color?
Thu, Jan 28, 2010 at 4:30:54 AM | Color of walls and window/door trim
4 Stars: 205 Votes
About the question of the "Trim/Moulding", is that created in the same family of the door? Pick in that, go to the properties and check if you have a instance or type parameter for that material then change for whatever you want.
About the "Paint" the wall, well you have the "Paint" tool to assign materials to the faces of the objects but you can assign materials directly to the "layers" of the wall when you go to properties of the wall and "Edit Structure" you can give the "Function, thickness and Material" for those layers....
Stone wall covers door and window trim?
Thu, Jan 3, 2008 at 8:50:32 AM
Wall Finishes Aligned to Door Trim
Thu, Jan 21, 2016 at 4:08:48 PM
Door Trim Parameters
Fri, Sep 11, 2009 at 12:52:57 AM
Windows, Walls, Trim
Mon, Jun 9, 2008 at 12:15:01 PM
Brick Wainscot Covers Door and Window Trim
Thu, Mar 19, 2009 at 1:24:50 AM
Page generation time: 0.6270
