Forums >> Revit Building >> Technical Support >> filter/ deleting item
Thu, Sep 8, 2005 at 1:08:49 PM | filter/ deleting item
karok
is there a way to search for a specific item? I imported an autocad drawing into revit, inorder to overlay it. That was a while ago, I forgot about it, and now I can't find it to delete it manually. How can I find it to erase it?
Thu, Sep 8, 2005 at 1:13:40 PM | RE: filter/ deleting item
karok
ok, just remembered that I unloaded it. But the question stands. Is there a "filter" type command in revit?
Thu, Sep 8, 2005 at 2:34:00 PM | RE: filter/ deleting item
TomDorner
4.5 Stars: 25 Votes
After you select the items, you can filter them by clicking on the filter icon. You can also select all instances of an item by highlighting it and right click to 'select all instances'. In addition you can go the the families section in your project browser, highlight a family name and right click to select all instances. HTH Tom
Thu, Sep 8, 2005 at 2:42:45 PM | RE: filter/ deleting item
karok
thanks
Deleting Detail Item
Tue, Sep 22, 2009 at 3:06:05 AM
Filter by Material
Wed, May 27, 2009 at 2:08:09 PM
Things getting Deleted!
Thu, Apr 2, 2009 at 8:29:50 AM
Filter turns everything off
Wed, Apr 19, 2017 at 9:25:54 AM
Managing multiple copies of a building section in the same project
Thu, Oct 24, 2013 at 1:50:21 PM
Page generation time: 1.6880
