Forums >> Revit Building >> Technical Support >> Level Question
Wed, Jan 27, 2010 at 2:47:14 PM | Level Question
rmwilkening
I was adding levels to project via an elevation view. Everything looks like I need it to appear in elevation view. However when I cut a building section the level marks are no longer present in that view. Does anyone know what is happening? I check in the visibility graphics menu and it shows that the levels should be visible. I
Wed, Jan 27, 2010 at 3:29:49 PM | Level Question
TKennedy
4 Stars: 8 Votes
If the Levels catagory is turned on in VG, it's likely an extents issue. If the 3D extents of the level (or grids) don't go through the crop of the section, they won't be shown. In the section view properties turn off Crop View and change Far Clipping to No Clip and see if they show up.
Wed, Jan 27, 2010 at 4:32:24 PM | Level Question
rmwilkening
It seems that everything goes through the section cut, so I am not sure what is going on but I did try what you suggested and it worked. The only thing is that it would be nice to have a clip portion to the section cut. Is there something that I might have done work with creating the levels that would make this happen?
Thanks for your response
Thu, Jan 28, 2010 at 9:31:35 AM | Level Question
TKennedy
4 Stars: 8 Votes
When I sugested to turn the crop and clip off, that was just so you could find the levels. Once you find them and get the extents in the right place you turn the crop and clip back on. Somthing that I do in all my projects is set up a couple of elevations cutting well outside the extents of my project (more if the project has non orthoganal parts) and are not cropped or clipped. They don't go on any sheets, but they give me somewhere to go to check on the extents of my levels and grids.
View Range :Option Question
Fri, Nov 25, 2011 at 2:14:25 AM
Multi-level roof question: need help
Mon, Dec 10, 2007 at 10:48:38 AM
split level homes
Tue, Feb 17, 2004 at 7:04:24 AM
Stairs: multistory top level question.
Thu, Aug 16, 2007 at 11:44:38 AM
Multi Level 3d into Single Level 3d
Thu, Jun 18, 2009 at 2:02:02 PM
Page generation time: 2.8801
