Forums >> Revit Building >> Technical Support >> Casework below countertop not visible.
Wed, Jan 27, 2010 at 1:01:05 PM | Casework below countertop not visible.
citywillsaveus
Hello. I have built a casework family in Revit 2010 which shows the casework below the countertop as a hidden line, which is what I want. When I load it into my project however, the lower casework is not visible. I have gone through all of the visibility settings and "Plan Rep - Below" is checked in all instances. I'm not sure what I'm missing here. Help?
Wed, Jan 27, 2010 at 1:06:40 PM | Casework below countertop not visible.
38fordor
Check your Object Styles in the project and see if the line weights are the same.  The Project Rules, and will always override your family settings.
Wed, Jan 27, 2010 at 1:12:28 PM | Casework below countertop not visible.
citywillsaveus
The object styles seem to be set correctly, with a dashed line for casework below. All my other casework shows up properly in the project, it's just this custom created family that is screwy.
Wed, Jan 27, 2010 at 1:21:52 PM | Casework below countertop not visible.
38fordor
Your countertop is obscuring the cabinets below.  Within the family you could turn off the countertop visibility in plan view and use symbolic lines.  Conversely you could use dashed symbolic lines to represent the cabinets below.
Wed, Jan 27, 2010 at 2:11:54 PM | Casework below countertop not visible.
Have you tried the "Show Hidden" tool?  Modify - Show hidden - pick the counter then the cabinet.
Wed, Jan 27, 2010 at 2:16:58 PM | Casework below countertop not visible.
citywillsaveus
Thanks, I did the symbolic lines trick for the countertop, and that allowed me to show the casework in the desired manner.
Formulas in Tags
Thu, Mar 20, 2008 at 11:08:07 AM
Change casework height based on countertops height
Tue, Jan 3, 2012 at 1:19:43 PM
Countertop Invisibility
Mon, Jan 5, 2009 at 1:46:39 PM
How do I add a countertop to the Base Cabinet - Corner Unit Angled?
Tue, Mar 28, 2006 at 3:39:10 PM
Casework below in-place component won't show - R09
Fri, Dec 4, 2009 at 11:50:12 AM
Page generation time: 0.1051
