Forums >> Revit Building >> Tips & Tricks >> Revit TotD – 1.26.10 | Quick Access Menu and Worksets
Wed, Jan 27, 2010 at 9:00:26 AM | Revit TotD – 1.26.10 | Quick Access Menu and Worksets
rkitect
rkitect Avatar
4 Stars: 29 Votes
Oh my, two new tips in one week!? This may become a new routine! Here’s one for those of you that use worksets a lot. Those of you that have used worksets on a project after recently converting from AutoCAD probably note a similarity in layers and worksets. Right down to loosing track of which workset you are currently working in! Up until now, there was not an easy way to see which workset you are currently working in. You have to open up the workset dialogue, and set the workset. Now, however, through the magic of the Ribbon, there is a much easier method!
Cut and dry, very simple. Go to the Collaborate Ribbon and look to the left in the Worksets section (note this requires a project that actually has worksets).
Right click the workset selection drop down, and select “Add to Quick Access Menu.”
Done… yup, now look up at your Quick Access bar (did you even know you could do this? <img src=" /> )
You can now not only see which workset you are currently working in, but easily switch without opening up the workset dialogue! Maybe that new fangled ribbon isn’t as bad as you thought it was!
As always, you can see this tip in it's full glory at: http://revittotd.com/01/785.  Enjoy and have a great day!
-Carl Gibson
Edited on: Wed, Jan 27, 2010 at 9:01:41 AM
Revit TotD - 8.26.2010 | Quick Plan Perspectives (via View Cube context menu)
Thu, May 31, 2012 at 3:02:54 PM
Print Icon on Quick Access Toolbar
Wed, Oct 29, 2014 at 6:27:05 AM
Quick Access Toolbar 2011 losing tools on startup
Thu, Aug 19, 2010 at 6:43:53 AM
Mirror about manual axis in 2010??
Fri, May 1, 2009 at 1:26:16 PM
Revit TotD – 7.23.09: Family Materials, Parameter Application
Thu, Jul 23, 2009 at 8:46:57 AM
Page generation time: 6.5268
