Forums >> Revit Building >> Technical Support >> Trouble getting furr down walls @ ceiling to actually be room bounding..........
Tue, Jan 26, 2010 at 11:33:55 AM | Trouble getting furr down walls @ ceiling to actually be room bounding..........
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
I am using a calculated formula for "Average Ceiling Height" in my room schedule by dividing the volume by the area.  In this band room, we have a stepped ceiling with furr down walls at each step.  These walls are designated to be room bounding but they don't in this ceiling location.  I tried using a line separation but that is not available in section.  Any suggestions?
Tue, Jan 26, 2010 at 11:38:28 AM | Trouble getting furr down walls @ ceiling to actually be room bounding..........
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Here is the print screen view that shows the room boundary in blue.  The jpeg export didn't pick this up.
Tue, Jan 26, 2010 at 11:53:00 AM | Trouble getting furr down walls @ ceiling to actually be room bounding..........
I think room bounding walls have to intersect the floor the room is on.  You will have to add room boundry lines.
Tue, Jan 26, 2010 at 11:58:10 AM | Trouble getting furr down walls @ ceiling to actually be room bounding..........
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Are room boundary lines available in section?
Ceiling not bounding room
Wed, Oct 6, 2010 at 4:01:35 PM
room bounding problem
Fri, Jul 28, 2017 at 4:03:50 AM
13
Indicating a Furr Down
Tue, Aug 24, 2010 at 3:06:35 PM
Furr down and ceiling joins
Wed, Mar 16, 2011 at 7:47:52 AM
Low walls still room bounding??
Tue, Mar 24, 2009 at 9:54:54 AM
Page generation time: 1.4964
