32 Users Online (30 Members):
Forums >> Revit Building >> Technical Support >> is it possible to create an angled cut plane?
3 Posts No Rating |
i'm trying to set up my views of a sloping semi-circular driveway... to explain the geometry, you enter the driveway at elevation zero, as you drive to the center point of the arc you go up about 20 feet then continue back to zero exiting the driveway. along the side of this driveway there are battered walls sloping up and away from the driveway. i'm trying to get the view range to cut through the walls at a continuous slope. the only solution i've come up with is placing multiple plan regions along the slope. any other suggestions? version: revit 2009
Not a clear question. Are you talking about a plan view? You do know that you can rotate sections.
3 Posts No Rating |
Sorry...yes, plan view. I didn't know that I can rotate sections. I'll give that a try. Thanks!
3 Posts No Rating |
OK, I set up a section in elevation view and rotated it to be parallel with the sloping ground plane. Worked perfectly, thank you!!!
Window with angled sill |
Fri, Nov 16, 2012 at 10:49:57 AM
DRAWING ANGLED WALLS |
Wed, Feb 20, 2008 at 7:53:29 AM
Revit 2011-putting openings in angled walls. |
Sat, Sep 10, 2011 at 5:45:27 AM
Angled window opening in plan view |
Thu, Aug 15, 2013 at 2:18:12 PM
11
Add "grouting" between a flat wide base and angled narrow top |
Sat, Mar 13, 2010 at 7:40:32 AM
