Forums >> Revit Building >> Technical Support >> floor to wall connection detail
Mon, Jan 25, 2010 at 2:55:03 PM | floor to wall connection detail
chilenito
If I build a exterior stacked wall (stucco wall over 18" concrete foundation), I would like to show the correct detail for a crawl space, connecting the ext wall  to the first floor.
So for a crawl space I need two 2x on top of the conc wall, and then the floor over the two 2x. The floor will have the structural & finish elements (1/2" carpet over, 5/8" ply over 9" I joists).
How can I show this in a building section?
My best guess is to have the floor at level 0, and have the foundation conc wall stoping 10 1/8" below level 0, leaving room to draw the 2x's.
how would you do it? am I putting too much detail in to the wall section?
Matias Santini
Mon, Jan 25, 2010 at 3:04:31 PM | floor to wall connection detail
In details, learn to use the edit cut profile tool.
The connection between wall and floor
Fri, May 14, 2010 at 8:43:26 AM
Structural Connection not visible in Detail
Thu, Feb 23, 2017 at 10:42:26 PM
wall floor connection
Mon, Nov 9, 2009 at 1:45:05 PM
Piping Medium Detail Issue at Mechanical Equipment Connection
Thu, Sep 27, 2012 at 3:45:11 PM
Wall and floor connection/cut
Tue, May 8, 2012 at 3:43:26 PM
Page generation time: 1.6857
