Forums >> Revit Building >> Technical Support >> offsetting node points..
Mon, Jan 25, 2010 at 9:29:16 AM | offsetting node points..
fred1021
I have two member connecting to each other but they are not centered on one another so the node points dont line up in the analytical model. Is there a way to offset node points so in the analytical model the node points line up. So when i export it to my analysis software it reads it correctly.
Mon, Jan 25, 2010 at 9:31:03 AM | offsetting node points..
fred1021
The member is a column not a beam.
Ref Planes and Node Points?
Tue, Nov 18, 2008 at 6:51:49 AM
Topographic points
Thu, Nov 27, 2008 at 9:22:44 PM
Revit Dimension Straight Leader Line with Controllable Node at Elbow
Thu, Jul 12, 2018 at 12:32:47 PM
Possible to place contour lines to toposurface instead of points?
Fri, Jun 1, 2018 at 2:57:52 PM
Curved node
Fri, Sep 28, 2012 at 9:53:40 AM
Page generation time: 0.2568
