21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> can't demolish half wall???
37 Posts No Rating |
Anyone ever have this problem before. I tried lowering the cut plane so it crosses the 1/2 wall but still the demolish tool is not an option. No problems demo-ing full walls. Is it an unconnected wall thing? Any insight would be greatly appreciated. Thanks! Eric
Revit cannot demolish half an object, but you can split the wall and put the two parts into different phases.
18 Posts No Rating |
Hmmm that is very strange, Im able to demolish half walls over here, are you sure they are referenced to the correct plane?
7 Posts No Rating |
Try changing the demolition phase in the element properties if the demolish tool doesn't work.
SOLVED! I was trying to demolish a new wall...dumb mistake. Thanks bgdragon et al.
Un-Demolish |
Tue, Jan 2, 2007 at 4:16:58 PM
Demolish wall alyer |
Fri, Aug 1, 2014 at 10:37:24 AM
demolish door with out infilling opening |
Fri, Jun 5, 2015 at 9:30:39 AM
Clean up Demolish Wall... |
Mon, Nov 8, 2010 at 7:52:01 PM
Demolish Tool |
Thu, Sep 13, 2012 at 6:20:41 PM
