Forums >> Revit Building >> Technical Support >> Editing skylights
Fri, Jan 22, 2010 at 9:53:46 AM | Editing skylights
EugenioFV
Hey, great forum...and sorry if this question is basic/obvious...im sort of elarning revit in an office that no one knows and I have no one to ask here.
About my problem. Im creating a skylight in an all concrete building, its sides are slanted, and to achieve this I created a massing to which I made its sides 4" concrete walls. I then placed this walls over the roof which has a series of angles. I then created vertical openings where the skylights break thru the building and joined the wall/roof geometry. The problem Im having is I cant find a way to alter the skylight walls to hug the contour of the roof their are cutting. What I end up with is the skylight extending below the rood line, and what I need to show is it being flush, almost as if the skylight is a bending of the roof skin. The walls wont let me edit or cut their contour, so I am out of idea...perhaps this wasnt the best idea to solve this problem in the first place.
Anyways I have included a couple of images, any help would be amazing, Thank you.
-E
Fri, Jan 22, 2010 at 9:56:29 AM | Editing skylights
EugenioFV
EDIT:
On image one is one of the biggest problems I have, roof slope continues behind that skylight, so its bottom edge will have to have an inverted V shape so it can hug the roof.
window schedule - skylights
Wed, Jun 7, 2006 at 10:00:02 AM
Adding skylights and slopes to a roof
Thu, Jul 12, 2012 at 8:33:07 AM
Skylights and Ceilings
Thu, Jul 9, 2009 at 5:01:30 PM
cant get color out of the view
Thu, May 1, 2014 at 2:12:47 PM
Wall/Roof Attachment Phasing Issue
Wed, Aug 27, 2008 at 2:34:16 PM
Page generation time: 0.4205
