Forums >> General Discussion >> Wishlist >> Multi-profile Sweep
Thu, Jan 21, 2010 at 3:11:35 PM | Multi-profile Sweep
JRMello
Alright, here's another one: a sweep that has one path but lets you add multiple profiles to it. I frequently create objects from sweeps that have the same path and have to copy and change the profile for each part, and then if I need to change the path I have to do it as many times as there are profiles in the family.
Thu, Jan 21, 2010 at 8:05:40 PM | Multi-profile Sweep
Why don't you copy clip the path and paste it back for each sweep.
Fri, Jan 22, 2010 at 7:35:53 AM | Multi-profile Sweep
JRMello
That's what I currently do, but as I said, if I need to make a change to the family and it has 3 sweeps then I need to change the path 3 times. If it was a multi-profile sweep I could change the path once and have all 3 profiles follow it. Sort of a special case wishlist item, but I guess I was curious if others could see it as being useful too.
Fri, Jan 22, 2010 at 8:08:14 AM | Multi-profile Sweep
4 Stars: 205 Votes
If you use Revit 2010 with the new "Conceptual Mass" you can create that kind of "Shapes" you need...
Complex profile sweep
Fri, Feb 6, 2009 at 2:08:35 PM
12
Custom profile for wall sweep
Mon, Jul 1, 2013 at 2:06:01 PM
11
profile sweep help
Mon, Sep 21, 2009 at 4:48:04 PM
Sweep profile rotates
Tue, Oct 23, 2012 at 2:37:24 PM
C-Channel Profile sweep issues?
Fri, Apr 29, 2011 at 11:47:24 AM
Page generation time: 0.1784
