17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Storefront Grids
39 Posts No Rating |
I have an interior curtainwall that is curved (faceted) in 2' sections. I need to have horizonal members at different heights in each 2' panel sections (see attached picture). Is there any way to do this?
Very easy, after you create your "Curtain Wall" you have the "Curtain Grid" tool to divide the panels like you want, look the images attached.... Use the "One Segment" to create that...
any tips for 2009? I don't see the "curtain grid" tool. I can click on the existing horizonal grid and select the "add or remove segment" but so far can only figure out how to delete a segment, not add or move one! i have 2010, but had already started this project in 2009 and am in the CD phase and didn't want to switch over... if I can avoid it!
Do you need more?
Edited on: Thu, Jan 21, 2010 at 1:48:53 PM
essentially, what I need to do is outlined in the two attached images.
AHA!!! thanks so much for your help!
How to edit Curtain Wall Grids and remodeling windowall |
Tue, Sep 2, 2008 at 2:29:23 PM
Storefront Wall needs Storefront Doors |
Mon, Dec 3, 2007 at 8:58:52 AM
Phasing for storefront system panel |
Wed, May 18, 2011 at 7:44:36 AM
Angled/sloped storefront |
Wed, Nov 14, 2012 at 1:55:13 PM
window / storefront schedule, |
Thu, Sep 10, 2009 at 1:02:39 PM
