Forums >> Revit Building >> Technical Support >> Families' View Range
Thu, Jan 21, 2010 at 8:43:29 AM | Families' View Range
PatrickCheek
I have created an escalator family that contacts my ground floor to my third floor.  However, when I place it in the model I can see the entire length of the escalator in all plan views.  How to I adjust the view range... within the family or within the model?
Thu, Jan 21, 2010 at 8:46:04 AM | Families' View Range
It is probably a non-cuttable family which means if any part of that is cut by a view, the entire family will show.  You can read about cuttable families in your HELP.
Thu, Jan 21, 2010 at 8:51:44 AM | Families' View Range
PatrickCheek
Is there any way to switch this off or do I need to create a completely new family?
I cannot find it in HELP.
Thu, Jan 21, 2010 at 9:11:22 AM | Families' View Range
search cuttable in your help - that will tell you what family it needs to be to be cuttable.
Thu, Jan 21, 2010 at 9:13:04 AM | Families' View Range
PatrickCheek
Got it!  Thanks.  Speciality Equipment cannot be cut... so just switched it to Generic Model and it cuts beautifully.
In place families above the view range are still appearing
Tue, Dec 23, 2014 at 9:17:05 AM
view range for floorplan views
Tue, Sep 27, 2005 at 2:41:03 PM
View Range Odd Behavior
Wed, Dec 7, 2005 at 5:26:55 PM
window opening doesn't show in floor plan view
Mon, Oct 3, 2005 at 7:59:15 PM
Ceiling View Ranges: 2
Sat, Feb 23, 2008 at 9:25:24 PM
Page generation time: 0.8589
