Forums >> Revit Building >> Technical Support >> Edit Type Parameters
Wed, Jan 20, 2010 at 5:48:51 AM | Edit Type Parameters
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
RAC 2010
can i add the same parameter in allthe types within a family? can i edit that parameter for all typesat once?
Wed, Jan 20, 2010 at 7:24:39 AM | Edit Type Parameters
Not sure what you are asking but here is an answer... If you have a shared parameter in a family, then this parameter will be assigned to evey type within that family.  If you schedule that family and include that type, you can sort so all the types are in one line in the schedule.  Change that parameter in the schedule and it changes the value for every instance/type used in the project.  But only those used.
Edited on: Wed, Jan 20, 2010 at 7:25:21 AM
How do you edit mullion profile parameters
Thu, Oct 27, 2011 at 10:42:17 AM
Changing Family Type Parameters within the .rfa itself ... Am i on an island?
Mon, Jul 27, 2015 at 1:12:48 PM
11
Text TYPE PARAMETERS
Mon, Mar 19, 2007 at 8:46:40 AM
Cant edit family parameters?
Wed, Jul 15, 2009 at 1:36:26 AM
Cant Edit Topography Type
Fri, Jan 21, 2011 at 10:41:03 AM
Page generation time: 0.4532
