Forums >> Workflow & Implementation >> Worksets >> Extracting Sheet views which were created before switching to Central File
Tue, Jan 19, 2010 at 12:18:51 AM | Extracting Sheet views which were created before switching to Central File
Bhavani
Bhavani Avatar
The project was split into zones along expansion joints and each zone had a separate file with users working individually and it had sheets. Then we had to create a central file since coordination and trackin was tough with different files. When we linked them and made one central file with woksets for each zone the sheets were lost in the process. We were able to get only the data(3d and 2d content) in the corresponding levels using linked view in VG but sheet views were lost. Is there any way to retrive the sheet views when we switch to central file mid way?. This would help us in saving time in re-creating the sheet views for the central file from scratch.Thanks
Tue, Jan 19, 2010 at 10:28:55 AM | Extracting Sheet views which were created before switching to Central File
You will have to recreate the views and callouts but you can open the two projects side by side and transfer all 2D information between same views using copy to clipboard and paste.
Tue, Jan 19, 2010 at 10:11:01 PM | Extracting Sheet views which were created before switching to Central File
Bhavani
Bhavani Avatar
Thanks.We are doing that already.Smile Just wanted to know if there is some way to get it directly. sigh! Sad
Issues with links in central files
Fri, Apr 2, 2010 at 10:20:13 AM
Multiple Views Deleted in Central File - Please Help!
Fri, Apr 1, 2011 at 4:26:18 PM
Error - Local File Resides in Central File Location
Fri, Apr 9, 2010 at 8:34:55 AM
detach from central file
Wed, May 12, 2010 at 12:28:23 PM
can't save as a central file
Wed, Sep 9, 2009 at 2:35:47 PM
Page generation time: 0.8131
