Forums >> Revit Structure >> Technical Support >> A corner pilaster
Mon, Jan 18, 2010 at 6:12:01 PM | A corner pilaster
mark7321
I need to create a corner pilaster. (See attachment) I tried to create it by using the structural wall command but the pilaster is too small in length and I get an error message saying that revit can't create this wall. I also tried to combine 2 concrete columns but I couldn't get them to join together. I'm new at revit so I assume I'm missing something obvious.
Mon, Jan 18, 2010 at 6:49:29 PM | A corner pilaster
jarosa
jarosa Avatar
4 Stars: 5 Votes
Revit doesn't like small walls sometimes, but it seems it should be able to make these walls. Make the walls clockwise, set placement to exterior face or core.
If not you can make a custom column family. If you go this way be sure to lock the top of the column to the upper level in the family before loading into the project. Also, the center reference plane in the family is what you will align to grids, etc.
Concrete Pilaster at wall intersection
Tue, Sep 28, 2010 at 11:16:08 AM
Piers/Pilaster joins
Mon, Apr 28, 2008 at 8:50:54 AM
Pilaster
Sat, Jun 30, 2007 at 10:15:22 AM
Pilasters
Mon, Jul 2, 2007 at 11:14:39 AM
why the line?
Thu, Jan 21, 2010 at 12:08:36 PM
Page generation time: 1.7009
