Forums >> Revit Building >> Technical Support >> Porject Phase on Title Block
Mon, Jan 18, 2010 at 5:00:42 PM | Porject Phase on Title Block
VonMuda
Hi Guys,
 I want to list the project phases as a label on the title block, but I'm not having a lot of luck.  I can make a shared parameter, but what I really want to do is list the project phases as they are listed under 'Settings>Phases."  Any Ideas how I can make this happen?
Tue, Jan 19, 2010 at 7:06:54 AM | Porject Phase on Title Block
The title block has nothing to do with phases, views do.
Tue, Jan 19, 2010 at 9:36:10 AM | Porject Phase on Title Block
VonMuda
I  understand that.  My posted last night in a rush so let me explain a little better what it is that I am trying to do.
We are working on a project that has three phases and will be issued in three separate packages.  However, all three phases are being developed at the same time and in the same model.
We want to list the phase that each sheet is being issued in on the title block, so what I am trying to do is create a label in my title block file that ties back to the phases that are listed in the model and that would update if the names of the phases changes.
Hope that clarifies.
Tue, Jan 19, 2010 at 10:02:08 AM | Porject Phase on Title Block
Create a shared parameter - assigned to sheet that can be used in your sheet titleblock and also to sort your sheets in the browser.
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
How to import my title block from AutoCAD?
Mon, Sep 10, 2007 at 4:25:43 PM
12
In the default Revit Templates i couldnt find revit title block
Fri, May 23, 2014 at 7:22:23 AM
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:26 AM
project title block
Tue, Dec 1, 2009 at 2:18:45 PM
Page generation time: 0.1838
