Forums >> Revit Building >> Technical Support >> Schedules - Splitting Same Schedule in different ways?
Mon, Jan 18, 2010 at 4:32:09 PM | Schedules - Splitting Same Schedule in different ways?
markdstonerii
I am trying to use the same schedule on two different sheets; one in one complete column, the other in two split columns.  However, when you split it on one sheet, in splits it on ALL sheets.
Is there any way to get this to work without duplicating the schedule???
 Thanks, and sorry if this problem has already been solved on another thread...I search long and hard before posting a new one, I promise! Smile
BTW, Revit2010.
Wed, Jan 13, 2021 at 3:45:58 PM | Schedules - Splitting Same Schedule in different ways?
hanbyjm
I have a similiar situation.  I have a schedule that is way to big for just one sheet.  Is it possible to split a schedule so it can fit on 2 different sheets?
Wed, Jan 13, 2021 at 4:11:53 PM | Schedules - Splitting Same Schedule in different ways?
Here is one way but I never did this: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-split-a-long-schedule-on-multiple-Revit-sheets.html
Instead, I choose a field that I could use to split my schedule into two schedules.  For instance you could have all rooms below 200 in one schedule and remaining rooms in another.
However, if you have columns that may be totaled, you might be better to use the first solution.
Thu, Jan 14, 2021 at 7:01:49 AM | Schedules - Splitting Same Schedule in different ways?
hanbyjm
Do you duplicate the schedule and then use filters? We have different Departments so I could filter by departments.  We thought about just making separate schedules for each department.
Thu, Jan 14, 2021 at 12:29:21 PM | Schedules - Splitting Same Schedule in different ways?
Yes, duplicate - rename and the change the parameters.
Schedules for Information In Schedules HAHA
Mon, Feb 13, 2012 at 12:08:12 PM
Combining Room Schedules and Area Schedules into one Large Schedule
Thu, Jan 3, 2013 at 10:57:33 AM
multiple schedules
Tue, May 1, 2012 at 1:04:42 PM
Schedule
Thu, Jan 15, 2009 at 10:18:27 PM
Schedules: Ie Door schedules!
Fri, Jul 11, 2014 at 2:58:22 PM
Page generation time: 0.2215
