Forums >> Community >> Newbies >> Floor framing not showing up
Mon, Jan 18, 2010 at 1:14:22 PM | Floor framing not showing up
Runyank
I am using revit structure 2010, and have all my floor framing modeled.  When I link in my grid/column file, it makes my framing dissappear.  When I unload the link, it re-appears as it should, with hidden lines under the slab.  Why does the link make the framing disappear?
Mon, Jan 18, 2010 at 1:48:36 PM | Floor framing not showing up
emgeeo
3.5 Stars: 7 Votes
What do you mean by link-in your grid/column file?
Are you importing from CAD/another program? Is there a slab on your grid/column file?  Are you linking Revit files?  Tell us more.
Mon, Jan 18, 2010 at 2:59:47 PM | Floor framing not showing up
Runyank
I am linking in a seperate revit model which containes only my grids and columns.  The building is being broken into 6 seperate revit models, and in order to have them all coordinate, we are all linking in the same model containing the grid/columns.
Fri, Jan 22, 2010 at 1:47:17 PM | Floor framing not showing up
emgeeo
3.5 Stars: 7 Votes
You seem to be treating it like AutoCAD.  This has been a hot-topic at my firm, but the reality is this: each discipline (revit file) really needs it's own grids and levels.  These elements are necessary in order for Revit to function- these system families are the backbone of Revit.
That doesn't really answer your question though- the linked-in model has no slabs?
Framing Plan
Tue, Jan 3, 2006 at 4:10:28 PM
12
What should the Revit Structure Cut Plane Depth be set to on framing sheets?
Mon, Nov 21, 2011 at 1:44:28 PM
Walls not showing in plan region
Mon, Feb 18, 2008 at 1:59:12 PM
14
Can't see Structural Framing from attached Revit Link in any Floor Plan
Thu, Mar 8, 2018 at 3:01:11 PM
11
Creating 2D Framing Plans
Tue, Oct 21, 2008 at 8:38:59 AM
Page generation time: 1.2363
