13 Users Online (12 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stair Issues
Sun, Jan 17, 2010 at 4:37:32 PM | Stair Issues
tydalwaves
Hi,
    I recently ran into a problem with modeling a set of monolithic stairs that are curved.  At first I thought it was a visibility issue, but at closer inspection, I'm guessing it has to do with some setting, but nothing that I've tried works.  Anyone have an idea how to fix it?
 Matt
Mon, Jan 18, 2010 at 12:56:58 PM | Stair Issues
4 Stars: 205 Votes
Wierd, this is what are you trying to do?
Mon, Jan 18, 2010 at 1:11:13 PM | Stair Issues
Looks to me like you have a scope box turned on in that 3D view.
Mon, Jan 18, 2010 at 4:36:21 PM | Stair Issues
tydalwaves
Hi guys
 Thanks for getting back to me.  I don't think that its a scope box issue.  Note that I sent two views...one is the 3d, while the other is an elevation.  The stairs seem to cut off at a certain distance parallel to the underside of the stairs.  The same stair sketch works fine with a non-monolithic stair type.  This is not for a particular project,  I'm teaching an intro Revit class and one of my students presented me with this problem.  The issue seems to occur when the curve becomes tighter.... I see that your demonstration works well, typhoon, but I wonder if you'll run into the same problem if you make the steps belly out at a tighter radius.   I appreciate you guys taking the time.   This problem has got me stumped.  Here's the file
Tue, Jan 19, 2010 at 3:31:28 AM | Stair Issues
4 Stars: 205 Votes
Right now i don't have Revit here but i take a look later....
Tue, Jan 19, 2010 at 11:56:48 AM | Stair Issues
KingRevit
4 Stars: 12 Votes
tydalwaves.
there is lots wrong with your stairs and it is not a visibility issue, but rather badly made stairs, im suprised revit actually made them.
easiest thing to do is start again, and do it proberly.
1st you have the worong number of risers 6 when 7 is desired
2nd your risers don't trim with your boundry
3rdly- where the hell is you run line? Revit should not make this stairs.
this is all basic stuff that you should know before tesaching someone else revit, sorry i don't wosh to be mean, but this is a very simple stairs to make and before you teach other you should really have a good grasp of the basics.
Tue, Jan 19, 2010 at 2:22:46 PM | Stair Issues
4 Stars: 205 Votes
Hi King, how are you man??? don't be rude with the guy ok? Puh
Here a SIMPLE solution if you don't want to recreate the stairs but i must agreed with Kingrevit in several things he said...
see the video: http://www.megaupload.com/?d=5SI8K6ZO
Edited on: Fri, Apr 30, 2010 at 5:35:59 AM
Tue, Jan 19, 2010 at 10:20:07 PM | Stair Issues
tydalwaves
Hey,
 Thanks for the replies, both of you.  I can handle a little bit of criticism.  I've had to teach myself Revit, as there aren't many people using it where I live and I don't use it at my day job, yet.  I'll take a closer look at this.  In class I always give examples of stairs modeled using the run tool,  I guess I undervalued the importance of the run line to the stair model.
Issues with underside of stair
Tue, Mar 15, 2011 at 3:27:07 PM
Stair will not host railing
Wed, Oct 10, 2012 at 12:19:23 PM
Stair Visibility Issues
Fri, Jun 7, 2013 at 8:58:58 AM
14
stair constraint issues - new user - revit 2008
Wed, Mar 26, 2008 at 1:50:54 PM
Can not swap out one stair family for another
Thu, Sep 19, 2013 at 12:24:19 PM
Page generation time: 0.1669
