Forums >> Community >> Newbies >> Newbie question - what else (Toyo Ito)
Fri, Jan 15, 2010 at 3:15:23 PM | Newbie question - what else (Toyo Ito)
mradulovic
Hello.
My name is Milos and I'm architect from Serbia, who is also a newbie user of Revit Architecture. Frankly speaking, in begining i was reluctant to switch from drafting in AutoCAD to modeling in Revit cause i always thought that computer can't draw details (callouts)  in Revit like i can do in AutoCAD by myself. But since i realized how much time i save by letting computer draw sections, elevations i became a fan of Revit. And there's that other thing - i had an ultimatum from boss to start using either Archicad or Revit "cause we had to move to 21st century) even though he still gives me ideas on a4 paper and draws everything in one layer in AutoCAD Smile
But let's get to the point - I'm working on a residential building project in which i would like to incorporate some kind of wavy, aluminium or pre-oxidized copper panel, facade very similar to the wavy facade seen on the Toyo Ito's Hotel Avenue in Barcelona ( http://metalldesign.files.wordpress.com/2009/05/suites-avenue-hotel_barcelona.jpg Winking. Since i'm newbie i thought first i could model it in place with profile and then extrude it verticaly, But i get a solid cube-like body instead of ribbon which i could later edit with some holes etc...
How would you make something like that wavy facade?
Thanks in advance
Sincerelly
Milos
Fri, Jan 15, 2010 at 4:14:55 PM | Newbie question - what else (Toyo Ito)
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
You can try to use "In-place family" or "mass" (use the help file "F1" button - you'll be surprise how helpful they are) Either one of these can create a very unique shapes like the wavy facade you want. Play around with massing and in-place family by using extrusion, sweep blend, revolve, etc.
 "If you tell the truth, you don't have to remember anything"
Fri, Jan 15, 2010 at 4:16:50 PM | Newbie question - what else (Toyo Ito)
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Fri, Jan 15, 2010 at 4:20:33 PM | Newbie question - what else (Toyo Ito)
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Sat, Jan 16, 2010 at 5:55:18 AM | Newbie question - what else (Toyo Ito)
4 Stars: 205 Votes
look what "Curtain Walls" can do, take a look at this: http://autodesk-revit.blogspot.com/2008/09/concrete-cladding-panels-as-curtain.html
also, check the rest: http://autodesk-revit.blogspot.com/search?updated-max=2009-04-24T14%3A29%3A00%2B01%3A00&max-results=50
Edited on: Sat, Jan 16, 2010 at 5:56:07 AM
Facade Help (Toyo Ito tree concept)
Thu, Apr 14, 2011 at 10:12:19 AM
sendai mediatheque
Mon, Dec 27, 2010 at 3:58:29 PM
Extruded roof - fascia - (Newbie question)
Wed, Jul 5, 2017 at 8:12:43 PM
13
MAKING A CUSTOM WALL
Sun, Feb 1, 2009 at 1:35:00 PM
Newbie Grid Question Revit 2008
Tue, May 15, 2007 at 1:48:03 PM
Page generation time: 1.7965
