22 Users Online (20 Members):
Forums >> Workflow & Implementation >> Worksets >> Can't create workset in Revit Architecture 9
7 Posts No Rating |
I am working on a project and I'm ready start the worksharing process. To begin, I clicked the workset button on the toolbar and the worksharing dialog box appeared. I accepted the default names and clicked OK. At this point it starts tging through the process and the bar across the bottom of the window only makes it to 10% followed by nothing. My file size is 75,000KB. I have made several attempts at this and have let it run for over an hour with no results. This is the third project that I have attempted this process and the other two had no problems. Is there something that I am overlooking? Has anyone else had similar problems? Any help would be appreciated.
7 Posts No Rating |
After purging, resaving and removing the linked .dwgs the process still wasn't working. At that point I tried opening the file from the pull-down menu with the "audit" boxed checked and still nothing. Luckily, my office just got a new computer myself which has a quad core and 8 GB of RAM and 64 bit operating system, so I tried running the process on that and it worked. I even tried to do it with the orignal larger file version and it worked as well. The total time required for the larger version was about 30 minutes. So I guess the true culprit here was my old computer (that was only a few years old) which only had only a dual core and 2 GB of RAM.
WORKSET CAN'T CREATE IN DIFFERENCE SUITE SET |
Tue, Jun 11, 2013 at 8:40:56 AM
workset or linking |
Mon, Jan 19, 2009 at 9:10:05 AM
Can't Edit Workset Parameter |
Thu, Oct 23, 2008 at 11:36:23 AM
Pipe visibility / workset problem |
Thu, Dec 22, 2011 at 9:02:36 AM
Hide a workset in a link |
Sat, Sep 20, 2008 at 10:04:45 AM
