Forums >> Revit Building >> Technical Support >> Multiple Wall Type Callouts
Thu, Jan 14, 2010 at 2:58:59 PM | Multiple Wall Type Callouts
JHuman
I have a floor plan I am working on, and I am currently putting in the wall type symbols.  There are several small spaces that need to be tagged, so is there a way to stem more than one line off of a single tag?  Help would be much appriciated.  Thanks!
- Doweth! [Homer J. Simpson]
Thu, Jan 14, 2010 at 3:55:20 PM | Multiple Wall Type Callouts
I usually slam one tag on top of the other... they will automatically line up.
Thu, Jan 14, 2010 at 5:11:59 PM | Multiple Wall Type Callouts
JHuman
This worked!  But there seems like there should be an "official" solution.  Seems like when it asks you to "Pick Host" you could select more than one item.
Fri, Jan 15, 2010 at 6:13:49 AM | Multiple Wall Type Callouts
JHuman wrote: "Seems like when it asks you to "Pick Host" you could select more than one item."  If you think about that, this can never - should not happen.  These tags are not static.  If they were, they could do what you want but these tags read their data from what you point to - just impossible to do with multiple items.
multiple section callouts
Wed, Jun 4, 2008 at 9:04:18 AM
Are Callouts Vew Specific?
Wed, May 12, 2010 at 3:56:06 PM
applying multiple hatch to wall
Wed, Jan 2, 2013 at 5:35:10 AM
Same Door Type, Different Frame Type
Thu, Jul 24, 2008 at 3:16:26 PM
Match Type on multiple elements
Thu, Feb 12, 2009 at 7:56:47 AM
Page generation time: 1.0188
