Forums >> Revit Building >> Technical Support >> mass not visible
Thu, Jan 14, 2010 at 1:06:10 AM | mass not visible
leeroy
why is mass constantly made not visible by Revit? I never make my mass objects not visible myself (why have mass if you cant see it?) but Revit is always making mass not visible for me!! HOW ANNOYING!!! is there a way to stop this happening so that mass is always visible unless I tick a box in the view to make it go away?
Thu, Jan 14, 2010 at 12:53:40 PM | mass not visible
4 Stars: 205 Votes
Did you try to turn ON the "Mass" in VG?
Thu, Jan 14, 2010 at 2:45:30 PM | mass not visible
leeroy
thanks typhoon, I know where to turn the mass on but why does Revit keep turning it off in some views?
Sun, Apr 11, 2010 at 9:55:50 PM | mass not visible
amstaples
Leeroy, Did you have any luck with this?
Revit seems to turn off mass visibility when you open the document after it being closed down completely? Is this a default revit setting which can be changed?
Andy
Thu, Jun 10, 2010 at 9:44:18 AM | mass not visible
BDerrick
3.5 Stars: 3 Votes
Bump - I'm having the same issue
Thu, Jun 10, 2010 at 9:56:14 AM | mass not visible
someone wrote: "...Revit seems to turn off mass visibility when you open the document after it being closed down completely?..."
This is not true.  Mass being on or off is simply a VG setting for any view just like other elements.  Learn to use view templates to control what is on or off in your views ... including mass.
Thu, Jun 10, 2010 at 11:40:19 PM | mass not visible
amstaples
WWHub wrote: "This is not true.  Mass being on or off is simply a VG setting for any view just like other elements.  Learn to use view templates to control what is on or off in your views ... including mass."
Thanks for answering my question. The 'view templates' is what we're after i believe. Revit2008 seemed to have these set as Mass being off as a default which i believe catches some users out... like myself.
Regards
Andy
Wed, Jun 16, 2010 at 12:39:25 PM | mass not visible
BDerrick
3.5 Stars: 3 Votes
Someone wrote: "This is not true.  Mass being on or off is simply a VG setting for any view just like other elements.  Learn to use view templates to control what is on or off in your views ... including mass"
 THAT is not true.  I open VG settings and turn masses on.  Next time I open the model... it's off.
Wed, Jun 16, 2010 at 12:46:35 PM | mass not visible
BDerrick
3.5 Stars: 3 Votes
Now I'm trying a few things to recreate the disappearance, I'll update my results...
Wed, Jun 16, 2010 at 12:48:41 PM | mass not visible
4 Stars: 205 Votes
" THAT is not true.  I open VG settings and turn masses on.  Next time I open the model... it's off." - WWhub is RIGHT, he told you "Learn to use view templates to control what is on or off in your views ... including mass." - he told you to use "View Templates".
Wed, Jun 16, 2010 at 12:57:10 PM | mass not visible
#11
BDerrick
3.5 Stars: 3 Votes
Right but view templates read your visibility graphic settings...
Wed, Jun 16, 2010 at 12:59:39 PM | mass not visible
#12
No .... view templates can control your VG settings...along with many other settings.
That is why they are called a template.... they control - not read.
Edited on: Wed, Jun 16, 2010 at 1:02:05 PM
Wed, Jun 16, 2010 at 1:04:08 PM | mass not visible
#13
BDerrick
3.5 Stars: 3 Votes
Yes that's the same the thing I wrote but it doesn't change the fact that my masses went invisible.  You're both absolutely right I can set a view template up but I don't won't to have to apply it continually.  I'll post again if I can find out why they're disappearing...
Wed, Jun 16, 2010 at 1:07:49 PM | mass not visible
#14
4 Stars: 205 Votes
If you create in each 3D view the same View template and turn ON the "Mass" in VG, every time you enter in that project the masses stil visible... try it...
How do you hide mass created in adaptive componnents?
Tue, Jun 26, 2018 at 4:43:28 AM
Conceptual Mass Project Space Visibility
Fri, Jul 15, 2011 at 1:46:11 PM
massing - default color not visible
Tue, Jun 9, 2009 at 9:28:37 AM
Sweep Profiles and Path's Not Visible
Mon, Apr 23, 2007 at 7:59:28 AM
Cutting a section through a mass
Sat, May 16, 2020 at 4:21:54 AM
Page generation time: 0.6372
